Replacing the door gasket on a CB1200 and have a couple of questions.
What do you do with the slightly frayed ends of the new gasket? It supposedly is cut to length so if I trim it, will it be short? I would need to trim about 1/4" from each end to get past the fray. I assume that I can give it a little stretch to make up for this.
Where do you position the cut? I assume somewhere on the bottom - middle.
Anything else I am missing?
TIA.
TIA.
See pic below. Click to Enlarge
