It’s already bought and on the flue collar. It looks like it fits fine but I have no idea what I’m doing so wanted to verifyThis depends on the stove and the brand of double-wall stovepipe. If possible, test it out at the store. With a good fit, no cement or gasket is needed. If that's not possible, then measure the flue collar and compare to the stovepipe's inner and outer diameters.
An old Woodland and Selkirk double wall black not stainlessIt may be ok. What stove and what stovepipe?
That's right, I recall now, this is for the tent. Does it transition to chimney pipe before exiting?
It may be ok. Pictures of the flue collar and chimney solution are welcome.
That is quite dangerous. Double-wall stove pipe is still quite radiant and it is not designed or allowed for outdoor usage. It has no insulation, only an air gap between layers. This should have been done with chimney pipe which has real insulation and a much safter 2" clearance.Correct!
Nope, double wall all the way up and out
Oh no…that’s what I was asking the other dayThat is quite dangerous. Double-wall stove pipe is still quite radiant and it is not designed or allowed for outdoor usage. It has no insulation, only an air gap between layers. This should have been done with chimney pipe which has real insulation and a much safter 2" clearance.
The stovetop looks wet. Is there a cap on the stove pipe?
montanacanvas.com
montanacanvas.com
montanacanvas.com
Sorry if I was confusing. I think I referenced each term correctly and as I intended and even mentioned that Class A is not commonplace in that circle.I like the idea of the double wall pipe if you are customizing the jack in the tent roof. It will help with creosote build up which can be a problem in tents since they usually in single wall pipe rather than class A on the exterior.
Single wall pipe outside the tent when it’s 8 degrees F can collect some crud.
You likely won’t find a cap made to fit double wall stove pipe, but could rig one with an adapter.
The double wall 6” won’t fit your 6” jack since double wall will be closer to 7” or 7.25” outside diameter. But if you can customize it or get a special ordered jack flap…maybe.
Our tent has a 5” jack and single wall nesting pipe is snug.
View attachment 319601View attachment 319602
It was just leaking through the stove jack flap. The pipe hadn’t been installed yetThe stovetop looks wet. Is there a cap on the stove pipe?
I’m just going to refer to all your comments on this as it’s a pain to quote all on my phone.What’s the collar look like without the pipe in it. I had to trim a little of the crimped section so it would go all the way down. There are tabs inside my flue collar that stop me from hitting the wool blanket and baffle. Trimming also got me to the wider/upper section of the crimped area so it would self center and fit tighter on the inside the stove collar.
I understand that, though it's a bit different when talking about a 24/7 fire in one's 365 living quarters. When lives are involved I will err on the side of caution and safety.Me and every other hillbilly chasing elk are using single wall pipe.
I can always stand to be corrected.I understand that, though it's a bit different when talking about a 24/7 fire in one's 365 living quarters. When lives are involved I will err on the side of caution and safety.
Me too, I didn't know about the nesting pipe sold by Montana Canvas.I can always stand to be corrected.
