Here is a quick way to get heat up a block or SS chimney that works every time.
If your fortunate enough to have a metal coffee can with a plastic lid at home-
1. Fill the coffee can half full or more with charcoal briquettes and soak them liberally with lighter fluid.
2. let it soak into the briquettes overnight(or afew hours if you are short on a fire starter.
3. Remove 6-8 briquettes and place them on two or three full sheets of news paper.
4. If you have a 4 pound hammer break the briquettes with the long flat side of the hammer
being the top flat and the briquettes will begin to break up continue this until
the briquettes are all broken and in small pieces.
5. Roll the news print into a tube making sure the broken briquettes are along the short edge and not
spilling out from the news paper tube.
6. Fold the open ends of the news print tube under each end and then place the tube of news print
in the fire box. use a Bernz-O-Matic Fat Boy Torch to light the paper tube and continue lighting it for a minute or so.
7. The briquettes will be burning fully by now and you can add small splits to begin a bigger fire.
Short of buying bags of matchlite briquettes-or off brand match lit briquettes it is less costly to do it this way.
