I have a DS Comfort Max 75 that I have been battling with for quite some time. This is my last effort before giving up and searching for a new stove. The stove is one of the last models where the data plate says it can burn wood and coal. At the time this was appealing to me because I wanted to keep it for a while and figured there may be a time that I don't want to cut firewood. (after reading posts on this forum I am regretful as I have learned it is difficult to have a stove that burns both well) I have only burned wood in this stove since day one.
Anyhow if you are familiar with the stove, the air is controlled by a bi-metal regulator. The main problem I am having is when I load the stove, the fire takes off and gets quite hot, about 600-650 deg F, before the bi-metal regulator finally catches up. At this point the bi-metal regulator eventually closes completely and after a little bit of time the flames settle and go out. However, the firebox is still really hot and gasses build up and then ignite suddenly. This causes the bi-metal regulator flap to blow open and it pushes pressure on the loading door as you can see a little puff of smoke come out. This will continue to happen unless I turn the regulator to allow air to enter the stove and actually re-ignite.
The above doesn't happen just once in a while, it is quite frequent. Additionally, the burn time of each load is quite short, partially due to me not wanting to load it to the max, given the inadequate control by the bi-metal regulator. I have tried everything in terms of changing up how I use the stove, installed a new bi-metal regulator, I have talked to the manufacturer, and I have talked to other wood stove dealers in the area. One dealer recommended adding a damper but in the manual for the stove, the safety instructions state not to do that. The stove is connected to a Ventis class A 6" chimney which is extends the proper distance above the roof. I appreciate you reading this post and any suggestions or information you may be able to provide. Thanks.
![[Hearth.com] DS Comfort Max 75 - Last effort before replacing [Hearth.com] DS Comfort Max 75 - Last effort before replacing](https://www.hearth.com/talk/data/attachments/305/305586-1f92049fb6992d2cc2ee0d1fe804c7ff.jpg?hash=1tMrrU7T22)
