Durock Next Gen - Hearth?
gloves12
36
Minnesota
A thread here on hearth 6 years ago said that durock next gen is not ok for hearths. Also discussed here in 2011, where people decided that maybe it was still ok. I'm still seeing a lot of threads where people are still using it for that. Some people even put in next gen, read the hearth.com thread, and considered re-doing the project (they ended up leaving it).
I'm building a hearth pad that needs an R value; and I bought a few sheets of next gen, but now I'm doubtful =) Is there any other options, now that we're at 2016? Has anyone with Next Gen had problems with crumbling, or with inspections? The answers from the company seem pretty clear that it shouldn't be used:
USG, 2013: "the Durock panel does not have a fire rateing by itself it has to be part of a a assembly to achieve a fire rateing durock is good up to 225 f Durock can be used in the installment of tile under the correct condtions
we do not recommend durock used in a wood stove install application i hope this helps" (page 4 here)
[Hearth.com] Durock Next Gen - Hearth?
I used Next Gen in my hearth.....but then again my stove requires ember protection only.
Reactions: gloves12
i found this link very helpful when deciding to build my hearth.
(broken link removed)
Reactions: gloves12
ifrc- next gen durorock has foam beads or similar infused in the matrix- hence the reason it is useless as a hearth pad , this was done to decease the weight of a sheet while somewhat maintaining the density as well as the moisture rating.
Reactions: gloves12
I used next gen on my hearth. FWIW, I threw some scraps in a brush pile and burned it. After about ten hours the Durock was still solid. Not that that is definitive proof. Just an observation.
Reactions: gloves12
I wouldn't worry about it, after all the sweeps library has next gen listed as a common hearth material and even has a "R" value listed. If that is what is readily available to you use it and don't look back.
Reactions: gloves12
I'd use 1/2 durock..that is what I did on my tile job under my wood stove. Make sure you really butter up the thinset/mortar. Tile don't like splits dropped on them. :)
Reactions: gloves12
Awesome, thanks guys. Is there anything else that would be better? I think wonder board has the same problem now too, right?
Pumice, not foam beads. There is a shower board product that has the foam beads in it, but not Durock NexGen.
I needed a quick hearth for my cabin. I used uncoated durock next gen. It passed inspection and 3 years of light (weekend) use. *shrug*
Reactions: gloves12
pour some concrete?
Well standard concrete is about r.1 per inch. I believe he needs r 1.5 so that would be 15" You cant just pour a 15' thick slab on a framed floor
i'm not sure how r-value works in this regards, but how about a non-combustible topping course (say 2" of concrete or cement board) with 2" of closed cell foam (r-7.5/in)?
Lots of people have used the published R-value of 1/2" nexgen (0.39) to design their hearth pads. In my case it was 4 sheets for my stove that required 1.5 R-value. I've seen no reports of any problems from anyone and it was easy for me to install.
Reactions: gloves12
The problem there is that foam is combustible so you would have 2" of concrete which would be r-.2 then highly combustible foam.
Just to reinforce what BG stated above...Next gen durock DOES NOT contain foam beads. The beads are a pumice product. Another common term is pearlited aggregate.
Reactions: gloves12
Awesome, thanks! I'm going to go for it, sounds like it's a pretty accepted method, maybe the only one, short of concrete.
