I'm glad I found this forum. We have had this Dutchwest 2461 for a very long time. It has always been frustrating and unpredictable. You can leave the air intake wide open for hours, and it will just sit there and smoulder, then all of a sudden it will take off and it's 95 degrees in the stove room.
This fall when I started burning it, I was getting a lot of smoke smell in the house. I could see puffs of smoke coming out from under the cover. So when it warmed back up in October I got a tube of furnace cement, pulled the cover, and ran a bead around all the seams on the top of the firebox. I also inspected the combustor and saw that it was partially eroded (only 1 year old).
The next time I fired it, it worked the best it ever had. No smoke smell. Fire took right off and burned. Air control even worked.
Worked, up until that Christmas storm. Then I started smelling smoke in the house again, but only when the fire had died down and the stove cooled off. Get the fire burning again and it would go away.
We got a couple of warm days last week so I let the fire go out and got ANOTHER tube of furnace cement and went over all the seams again. I also inspected the combustor and it is completely disintegrated. Supposed to last 4-5 years. This one didn't make a season and a half. Junk.
I did not have a replacement combustor and I needed heat so I put it back together.
The smoke smell is worse than ever, almost constant. However, I can not see any visible smoke coming from the stove.
Troubleshooting says, clean the chimney. I've cleaned it. Many times. It's clean. I don't know what else to do.
![[Hearth.com] Dutchwest 2461 smoke smell and failed combustor [Hearth.com] Dutchwest 2461 smoke smell and failed combustor](https://www.hearth.com/talk/data/attachments/307/307226-8c7ed52c545c7d1887781d9db4b34a10.jpg?hash=AB4Jgn8Dya)
