I read on one thread here that Dura-Vent said it was not necessary to screw a DVL adapter to the stove collar; only to the DVL pipe above it. Yet today I was told by Dura-Vent that the adapter should be screwed to the collar. My certified installer did not install screws.
Has anyone figured out what the best practice is? One arguement is as long as all the connections above the stove are screwed together, there is no need to screw the adapter to the collar. I've also heard the arguement that everything should be screwed down tight. Another approach is to screw all joints EXCEPT the slip joint to allow for expansion.
My thinking at this point is that I should probably tap the collar for 10-24 screws, cut them to an axact length to get through the outer adapter pipe and just to the inside of the collar, but no deeper. I'd also add a spacer or shim beteen the outer adapter pipe and the stove collar so I can torque the screws down snug without crushing the adapter; with a star lock washer just for grins.
I may be obsessing a little about this, but I rather not find myself living in the camper should the pipe overfire and make like a roman candle in the living room someday.
Thanks for the opinions
