Electric Chain Sharpening - Really this easy?
My friend bought one of though and they are junk. The plastic mount is very flimsy and it doesn't stay true. It took me much less time and better results to sharpen by hand.
That kind of grinder does work well but you need to get a decent model. They are in the $300ish area.
Check out Northern Tool, they have a $130 model that ain't horrible esp if you're not doing dozens of chains all the time.
Pretty simple once you get the hang of it.[youtube]http://youtu.be/5XLq5zemMss[/youtube]
Unless the chain has been cutting staples or rocks, you should BARELY be grinding. That chick is workin' it too hard!! :smirk:
I was there on issue with that cutting job at all. Watch the sparks. The other thing thats a cyclone wheel.
I'm no sharpening expert, but it does seem like she is grinding quite a bit. When I use my cheapo, all I do is kiss the chain then onto the next tooth.
Why wasn't she wearing the pink carharts for that?
Edit:OMG, I just noticed the video of her running the 880 while wearing them! Epic!
Reactions: Johnpolk
That wheel alone is 250.00 bucks. Really just kinda got to watch the spark count. She is only shinning that gullet. Takes 3-4 taps and pursure is every thing. Sparks dont lye.
Another one me one the 511a
[youtube]http://youtu.be/Ejqffmg-gWE[/youtube]
Does sound MEAN Though! It is the best set-up I have used.
This pic still has one tap to go. Takes very little off.
http://www.baileysonline.com/itemdetail.asp?item=AB6+18&catID=9997 Cyclone wheel!
  • [Hearth.com] Electric Chain Sharpening - Really this easy?
I have the same model from Northern Tool. I had sharpen a few chains before I figured out how to get the best results. It works pretty much like the one in the Harbor Freight video but it has more metal and less plastic. The adjustment that holds the chain tight has a handle that can be quickly released and tightened. The video didn't show that you have to hand file the depth gauges with a flat file.
Does anyone have this one yet?
Company website is here: http://www.timberlinesharpener.com/
Shari, I don't. Every so often a post comes up on the forums about this. Then I usually have another look at it on their website or watch the video showing how incredibly easy it is to use. I'm very tempted. I just wonder how long the carbide cutters last before needing replacement.
I like it but the draw backs price, time, and bits are expensive. With that said a pretty good grinder is much quickier and the stone last a long time if your using kool grind and a soft touch.
Bringing a damaged chain back to life would be slower with this tool than a grinder. Grinders will sharpen at any angle you please which this tool is limited to the available guides. It also can't take the rakers down so it's back to hand filing those. I see it only comes with one size cutterand the spares are $20 EACH. :bug: And what, no option for .404" chain? :lol:
It's a nice idea and looks to be a quality built product but for the money you can have a much more versatile grinder.
MasterMech said:
I see it only comes with one size cutterand the spares are $20 EACH. .
According to their website, they have cutters available in 7/32", 3/16" and 5/32". Apparently you can order your 'kit' with what ever size cutter you need.
So far, it's getting good reviews on another list that I am on: (broken link removed)
I have no affiliation to them, I'm just looking at the product for a possible future order.
I looked over that discussion at arboristsite.com. All 17 pages of the thread!! They are a long winded group of folks! :cheese: Looks like an awesome sharpener. Shari, I saw your postings "late in the game" on the topic. Did you ever get it ordered? Did you get a discount?
Has anyone else used one of the timberline sharpeners yet? I'm close to purchasing, based on reviews at arboristsite.com. $120 doesn't scare me too much. I like gadgets!
Reactions: Texas Chainsaw
Yes, I got my order in. I'm a total dummy on chain sharpening so I figured I'd need all the help I can get. :)
Well, I looked at the Timberline sharpener. Then I took the advice of a few ol' timers around here and bought a grinder. I chose the TimberTuff from Farm & Fleet. Works like a real champ. I love it.
the timber tuff sharpener...are u guys using the bench mount for 59 dollars or the upright bench mount for 150 dollars?....is there a advantage or disavntage?
I'm only familier with the unit that I purchased, pictured below.
Guys! I just want to say that buying the best is so much better in the long run.I have been down this road many times and dont want to see money wasted.I have used most of the bench grinders and I will say that you need to get an Oregon 411AX or similar or the Stihl USG.You can find them cheap at Russo.com.I know money is tight but so is wasted time and money on equipment that doesnt work.I bought one years ago from Harbour Freight and it actually made the chains worse than sharpening with a file.Save your money and spend the $400 for a good benchmount grinder and it will EASILY pay for itself.I own the Oregon 551462 with hydraulic assist and I think its the bomb but the other Oregon sharpeners are also great like the 410A or 411AX.The shops use the previous mentioned sharpeners because they work well.Just my 2 cents worth.Happy cutting and be safe!
That one looks to be a good model.
The one my friend has even the part that held the chain was plastic. There was no way you could be productive with it because you had to fiddle with the settings after each tooth and even still it was doing a poor job at sharpening.
Nate! That is a Oregon 410A or 411AX.That is a good machine and worth every penny.You can get them for around $200-$300 at Russo.com.
