Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks?
Don2222
9,257
Salem NH
Hello
During cleaning do you leave panel on or off?
This Eco Smart 27 KW electric DHW panel requires 3 - 40 breakers in the electric panel. It has 3 heating elements that we’re getting dirty with some scale build up. Therefore the hot water did not seem to be as piping hot as it should. Therefore I switched to the oil boiler for DHW with the 40 gallon superstore tank while acquiring some parts and knowledge to possible clean this thing! LOL
The Webstone tankless water heater service kit was the first one I came across at the big plumbing house but Home Depot actually has a very good price on it.
(broken link removed)
My issue with this kit is that the On Demand panel is mounted tight against the wall so no room to turn it around to fasten the Valves to the panel. There are what is called Spud Meter Connectors for $15 each to make this job easier but adds to the cost,
Then I found the HQMPC tankless water heater isolation valves kit. This has what they call a union but looks more like the spud meter connectors built in. However it comes with an adapter which has a nicely engineered wider flange for a better and easy connection to the On Demand panel.
So then I got 2 nipples with a nut for a wrench in the middle at Lowe’s for the bottom valve connection.
Just to make it a little quicker and easier, I got 2 - 3/4 shark bite Pex connectors instead of reusing the Pex connectors there after cutting the pex piping shorter to include the valves.
All the threaded pipe connections were more easily done with the 1/2” wide Blue Monster Teflon Tape. I cut the tape to approx 20” for 5 wraps to make a nice water tight connection. The Blue Monster is the easiest pipe wrap to use!
All this work went like clock work with a channel lock pliers and an adjustable crescent wrench and when it was time to run the cleaner it was super easy! The Whitman Flow Aid System Descaler kit did the trick. The cleaner is non toxic and works 20x better than vinegar. Therefore the cleaner only has to be run through the panel for 30 mins. :)
Amazon product ASIN B083ZFJD4PJust hook up the hoses to the valves and pump and put in a gallon of water with the quart of cleaner in the bucket that comes with this kit. Run the cleaner for 1/2 hour and then turn on the cold water to flush the rest of the cleaner out. Remove the hoses and turn the valves back to normal operation and bingo it is done!
Good DHW On Demand for another year!
Anyone else do this?
Was the water hotter when done?
How often do you flush it out?
The scale that is cleaned off is usually white calcium carbonate so you may not see real dirty water when done. You will notice hotter water and maybe better water pressure too.
So far after a day the water is nice and hot!
Pic 01 - Eco Smart Before Isolation Valves Installation
Pic 02 - Webstone isolation valve kit and 2 - 3/4" nipples
Pic 03 - Flow Aid System Descaler Kit & Blue Monster Teflon Tape
Pic 04 - Spud Meter Connector for Webstone Isolation Valve Kit
Pic 05 - HQMPC Isolation Valve Kit with built in union ( Spud Meter Connectors )
Pic 06 - Home Depot Pex Pipe cutter - Very Easy to use
Pic 07 - 3/4" Pex Shark Bite Connectors to 3/4" threaded pipe
Pic 08 - Connecting the Valve Kit, the hot and cold pex pipes need to be cut back with the new pex cutter.
Pic 09 - Valve kit all connected with safety release valve directed into bucket
Pic 10 - Valve kit all connected close up
Pic 11 - Valve Kit with cleaning hoses connected
Pic 12 - Cleaning solution pumped to Eco Smart and return fluid back into pail
Pic 13 - Cleaner Descaler
Pic 14 - Pump
[Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks? [Hearth.com] Electric Eco Smart 27 KW On Demand DHW Isolation Valve install for easy heating element cleanings. Any tips or tricks?
Nice video on testing and replacing a bad heating element!
Also if the Eco Smart is not putting out any heat which means 240 VAC to the elements.
1. Check the glass fuse near the temperature readout.
2. Check and replace the flow switch.
1. Fuse Replacement Video
2. Flow Switch replacement video!
Well that just convinced me to to buy a standard tank heater to replace my 23 year old unit I have now. Thanks
Reactions: Highbeam
I hug my electric tank heater every time I walk by. ZERO maintenance.
Reactions: begreen
My Rinnai tankless water heater came standard with the isolation valves you showed. I haven't bothered messing with it, I haven't touched the thing since I hung it on the wall several years ago
Reactions: Don2222
It is good to have the isolation valves:)
It all depends on water quality when DHW systems need maintenance. This electric tankless did not need maintenance for the 4 years I had it but this year there was a reduction in heat due to scale build up usually white calcium carbonate from the water supply. Therefore running the cleaner thru for 1/2 hour cleans the whole system. If it is done every year then the elements may last longer. I think I should have done it sooner before it got this bad!!!
On a electric tank, the whole tank must be drained to get the chips out and the elements must be removed and scrubbed to get the scale off. If not done on a regular basis the elements may need to be replaced.
I also have a SuperStor tank.
Did anyone try this Hot Water tank cleaning tool?
Amazon product ASIN B081MYSHYGThe Amazon reviews on it are very very good!
See video here on using this tool. :-)
Hello
I just did the nominal tank maintenance by just opening the bottom drain and draining the bottom sludge into a bucket outside. The new expandable hose is perfect for this job. There was some black bits and rusty water! See pics below.
An annual 1/2 hour On Demand panel flush & the 15 minute tank flush each year should really prolong the life of these utilities. :)
