Whenever I burn a load of wood, about an hour into it the stovetop temperature (375-450) goes up about 100 degrees (more wood = more rise) with some flames on the logs.  This process last about 30 to 45 minutes until the flames go out and the temperature drops about 150 degrees and stays there.  Is this normal?  Is there a way to prevent the temp increase in the 2nd hour because this is when most of the wood turns into charcoal. Would larger splits make this better or worse?
Encore 2550
			Encore 2550
		 .   And this is the first time I have seen a wood burning stove actually in action.  I've never heard the rumble in my stove.  Thank you for sending me to the links for the videos.
