I'm now entering my second year of basement wood stove burning. The first season was quite a whirlwind dealing with negative pressure, draft, and even starting a fire.
I think I'm in a good spot now as I can reverse a draft, get a fire going quickly, and keep it going for as long as I please. I still watch it like a hawk and constintely fiddle with the intake and check the temp at least once every 5-10 minutes. Anyway, because we don't rely on the stove for heat in the house I like to let the fire go out before heading to bed. What I've been doing is get all the large pieces burned/broken down and I'll open the air control to allow for max air intake keeping the flue temp around 300*. I'll do this and keep raking the coals around for an hour or two before bed and then completely shut the air control and go to bed. When I wake up morning nothing but ash is left in a cold stove.
Being that the basement has a naturally a strong negative pressure (I'm planning additional outside air intakes) is there something else I should be doing to ensure no CO2 gets pushed back into the house with the few coals left in the stove? Flue temp is usually still around 250-300*. Is there a flue temp at which the draft could reverse?
Also, if I head to bed with larger coals or even flames still going where should I leave the air control? Closed to smother or normal operating spot for continued burn.
That all being said/asked I have about 7 CO2 sensors through out the house and never had any show anything but a 0. Never would have thought this was so much more of an art! Thanks so much!
