When does everyone starts to clean out their wood burning stove, at the end of the burning season. Do you take all the bricks out so you can get all the ashes out the stove ?
I like to remove mine, to get all the ashes out,The bricks stay in. There's no need to remove them.
Why? I just replaced 3 back bricks last fall. That is the first time they have been touched since new, 14 yrs. ago.I like to remove mine, to get all the ashes out,
I just like to get all the ashes out that fell in between the bricksThe bricks stay in. There's no need to remove them.
I have never done that on any of my stoves or any customers stoves. There is no reason toI just like to get all the ashes out that fell in between the bricks
And those bricks would have lasted years more if you had just left them alone. The only time I might consider it is if it was in a very damp basement. Otherwise I see no reasonI remove everything in the spring; the bricks, the secondary burn tubes, the baffle. Gives me a chance to inspect the entire stove. Found delaminating bricks last year. I beleive ash is coorosive. Why let it sit against metal a full humid spring, summer, and fall? I like to start the season with a 'fresh' stove.
Might have started too soon this year. Cleaned the flue last week when it was 70F. Yesterday, last night and today....cold, blustery, and snow. Could have used a fire. Had to use the furnace.
When you do a cleaning for customers do you leave the baffle alone? My PE manual said I don’t need to remove the baffle. I have a slip joint on my double wall connector pipe.And those bricks would have lasted years more if you had just left them alone. The only time I might consider it is if it was in a very damp basement. Otherwise I see no reason
That depends. If I can just clean through the stove I pull the baffle. If I have to pull the pipe no I dontWhen you do a cleaning for customers do you leave the baffle alone? My PE manual said I don’t need to remove the baffle. I have a slip joint on my double wall connector pipe.
When the ashes get moisture it can do a lot of damageI remove everything in the spring; the bricks, the secondary burn tubes, the baffle. Gives me a chance to inspect the entire stove. Found delaminating bricks last year. I beleive ash is coorosive. Why let it sit against metal a full humid spring, summer, and fall? I like to start the season with a 'fresh' stove.
It hasn't in my stoves or my customers stoves.When the ashes get moisture it can do a lot of damage
The company that sold me these two BK's insisted on doing the first year's cleaning back in 2015/16, to see how I was burning. I finally conceded, and they showed up while I was away at work. My wife let them in, and I arrived about half way thru their job. I found the one guy hammering away inside the stove with a hammer and chisel, which my wife said they'd been doing for some time. Apparently he wanted to get every brick out, but I'd just finished several straight weeks of low and slow 30-hour burns on that stove, so the firebox itself was a crusty mess.I have never done that on any of my stoves or any customers stoves. There is no reason to
Ok, I'll bite. Please explain to me how removing the bricks and cleaning the interior of the stove degrades the firebrick. Be detailed. The bricks slide out and back in easily. They clean easily with a wide flat putty knife. I stack them flat on a tray in order. (I am a bit anal. I have to put each back in the spot it came from.) After interior is cleaned they are gently placed back in their location.And those bricks would have lasted years more if you had just left them alone. The only time I might consider it is if it was in a very damp basement. Otherwise I see no reason
It doesn't degrade them necessarily. But it's easy to crack a brick that would otherwise have been perfectly fine for years to come by pulling them. Even if they are cracked as long as they aren't moving and there are no pieces missing there is no need to replace. Then you have the floor brick. The majority of the time I need to destroy at least one to get them started up because of packed in ash.Ok, I'll bite. Please explain to me how removing the bricks and cleaning the interior of the stove degrades the firebrick. Be detailed. The bricks slide out and back in easily. They clean easily with a wide flat putty knife. I stack them flat on a tray in order. (I am a bit anal. I have to put each back in the spot it came from.) After interior is cleaned they are gently placed back in their location.
The stove was only used for two season when two firebrick showed delamination.
I want to look behind the firebricks to see what is going on. Any rust, any corrosion. I want to know what is happening with my stove. I do not want a 'surprise' someday when I don't need it. As I mentioned before, I believe ash is corrosive. I want to know what has happened during the heating season. I also do not want to leave the corrosive ash there during the non-heating humid season.Hey Tom, what do you think you're gaining by removing them? I think there can be a good argument to be made for inspecting, getting your eyes on what's behind them to look for rust or cracks. But if the purpose is to just get the stove "clean", what's the point of that?
