Englander 17-VL and EPA testing
Danno77
5,008
Hamilton, IL
Anybody know why there are two wildly different sets of numbers for the 17VL?
(broken link removed to http://www.epa.gov/oecaerth/resources/publications/monitoring/caa/woodstoves/certifiedwood.pdf)
I can only think two reasons, but I'd be open to others. Maybe Mike can comment on it.
1. One stove was sent for testing, testing results were not what was expected, so stove was modified and sent for new testing.
2. There are two slightly different versions of this stove floating around.
Ok, I can think of a third reason....Clerical!
Good to see that your Hearth-dar is working...
Am I reading it wrong ?
I only see a difference in BTU.
No, that's the only difference. But a difference between 19k and 43k is huge. I probably shouldn't have said "set" of numbers...
I thought that was kind of odd, too, but I have a tendency to ignore BTU numbers.
I'm sure it was wet wood. LOL
I have absolutely no idea what the second set of numbers is, but the lower ones (first on the list) are the correct values for this unit. I suspect this is a mistake at the EPA.
And just WHY should I believe you? %-P
Yikers, we have ghosts in Hearth.com.
