Do you know where he bought it from? Haven't seen it for sale anywhere.J-takemans buddy bought one. He has seen it first hand.
That's the only person I have heard of yet.
![[Hearth.com] Englander 25-IP [Hearth.com] Englander 25-IP](/talk/proxy.php?image=http%3A%2F%2Fi113.photobucket.com%2Falbums%2Fn229%2FDanZ51%2FPellet%2520Stove%2F537_zps85f86b05.jpg&hash=33abffcea1549d53aac89afb64c05498)
Nice job! Welcome to the Imperial Club!'Hate resurrect an old thread, but I recently (November 2014) installed an Englander 25-1P, as I write this I'm on my second ton of pellets and going strong.
I got a good deal from AM/FM energy (factory second). My installation is kinda unique as I'm below grade; 4" exhaust vent pipe, with a custom 2.5 mandrel bent for outside intake air. So far I love it! This is my first pellet stove after many years of burning wood, so I'm still learning. My first ton of pellets (Stove Chow) although burned well produced a ton of ash, My current, and second, ton (Blazer) burn great also with a quarter of the ash.
The stove is situated in a downstairs family room of 500 sq ft, with an open staircase leading to the main floor (newer modern home). I typically run between 3 - 5 settings. Much higher and I have to start stripping off clothes. Right now with temps in the low teens outside
, I'm at 4 and it's cozy warm. I use about two bags a day with it at 5. I still burn some oil (radiant heating) for the bedrooms, and hot water. I don't have too much to compare it to. But I am happy with it, so far.Oops! Missed this thread. Yep a friend down the road from me wanted a stove. I told him about the Englanders and AM/FM energy. I told him to look at the 25 EP. He jumped the gun and grabbed one from HD just after Thanksgiving. I helped him set it up. Seems to be a nice little stove. Only issue we say was it didn't blow a lot of hot air. He called Englander tech service and got it to throw more heat, But we both though it wasn't its full potential.
The draw back to this stove is not having convection tubes to convect as much heat as possible into the room. The box type heat exchanger isn't all its cracked up to be. Might be cheaper to make, But lacks area to absorb and transfer heat. So we added heat sinks to the top of the heat exchanger box. It increased the output, But still doesn't offer as much as a stove with tubes or an accordion type heat exchanger. There is a thread where someone added(posted picture) a heat sink to a 10 cpm. He also saw an improvement in convection temps.
I would look more at the 25EP which has a tube type heatexchanger. Unless you can steal a 25IP at a super low price.
Haven't seen too many of these ... How is it to keep the internal exhaust pathways clean? Easy access or ?
I dunno how much fact there is to this post about the box style heat exchanger being no good. I get real good heat out of my PAH which has a box style exchanger, enough to keep my entire 2,100 sq feet on two floors a comfortable 70-72*F when it's 20*F outside. The stove is only capable of 4lbs/hr, so its not wasting much energy in achieving that feat. It doesn't "feel" as hot exiting the stove as a tube type exchanger, but thats because the volume of air is so much higher flowing out of a giant set of louvers instead of 10-12 tiny pipes. Apples to Oranges comparison and not the stuff to determine which is more efficient.
The IP is something like 35kBTU output, which is pretty darn strong. I wish I'd looked hard at it when I was doing my shopping, it's a sexy stove!
Yes, it is worth noting that it is currently the highest output pellet stove that ESW makes, so I can't imagine the box exchanger is really that bad. It's been the sole heat source in my 1900sf house this winter and it hasn't been above 7 on the heat range.
Slight correction though, according to the manual,
Approximate Pellet Burn Rate**..........................................................0.945 to 2.346 kg/hrWhich is 2.08 to 5.17 pounds/hr
I was referring to my stove, which tops out at 4lbs/hr.
