OK folks......I'm officially at wits end with this stove. A little history, purchased in 2012, the stove has run well up until late last November. It was burning fine and then the flame slowly reduced to like it was set on heat setting 1. I've done all the recommended maintenance, replaced gasket in glass and door. passes flame and dollar bill test with flying colors. replaced combustion blower, replaced auger motor. Bypassed safety switches just to eliminate that as a possible cause. Used compresses air to clean all passageways. They are spotless. Replaced room blower (Has nothing to do with this issue but it was squealing. chimney and OAK are clean and clear. No blockages anywhere. It seem to be an intermittent issue. It ran well for January up until  yesterday when the flame went down to almost going out and adjusting the auger speed did not help at all. I opened the door and through in a handfull of pellets and the flame went back to normal until they burned away so it is definitely a fuel feed issue. So, with that said, i did manage to get it burning well but i had to adjust the low feed setting to 5 and the flame went back to normal and throws decent heat. Crazy right, setting 4 is better but not what i'd consider normal.
I'm thinking issue with control board? It's the only thing left really. Any help would be really appreciated. I am considering a Harmon at this point as the dealer is right up the road from me.
