Thanks so much for the side view pic. This is exactly the way I'l be needing to arrange my install; very helpful. I like being able to have the 45 degree stovepipe run. Wonderful install!
freeburn said:Did you add any firebrick inside? I added one in the back in between the two welded shelf/brackets. Two along each side. All of these on their sides. I also added 1 1/2 bricks on each side in front of the baffle toward the door vertically.
freeburn said:Anyone done anything else to increase that thermal mass or done anything different with the furnace? Don't hold forth.
lexybird said:freeburn said:Anyone done anything else to increase that thermal mass or done anything different with the furnace? Don't hold forth.
yes,i added some bricks along the sides as well ,will likely do the back section here soon
stee6043 said:Holy smokes.....77 degrees??? I'd be naked in my house all winter long if I kept it at 77 degrees! Nice looking setup.....
freeburn said:lexybird said:freeburn said:Anyone done anything else to increase that thermal mass or done anything different with the furnace? Don't hold forth.
All you need is one brick, unless you cut two for the outsides. Or carve out two just right so they fit around the welded brackets.
freeburn said:The bricks just stay there because the bracket is wide enough. As far as gains on burn time, I can't speak to that (I've never tried it without them), but perhaps more of a "keeping the firebox temps up" kind of thing to get a more complete-ish combustion of the wood. If anything, it retains the heat longer once the fire is out and perhaps keeps the firebox from warping/welting if the fire gets too hot. I kind of got the idea from the way all the other stoves are designed as well as the Caddy furnace inside, but without the secondary burn of course.
kieth4548 said:freeburn said:The bricks just stay there because the bracket is wide enough. As far as gains on burn time, I can't speak to that (I've never tried it without them), but perhaps more of a "keeping the firebox temps up" kind of thing to get a more complete-ish combustion of the wood. If anything, it retains the heat longer once the fire is out and perhaps keeps the firebox from warping/welting if the fire gets too hot. I kind of got the idea from the way all the other stoves are designed as well as the Caddy furnace inside, but without the secondary burn of course.
Ok I will give it a try. I was looking at the bracket inside and it seems like they would be constantly falling over since there is nothing holding them in but I will give it a try.
freeburn said:Could you get the same effect by adding firebrick on top of the baffle plate that is already in there?
laynes69 said:One thing to think about is the more firebrick, the less heat transfer on the walls of the furnace. Yes alot of firebrick is great, but you need heat transfer from the sides of the firebox. Thats why my old furnace heated so well, only the base of the walls were firebrick, which allowed for more heat transfer to the jacket around the firebox. The thicker the firebrick the more insulated the walls will be. Its better for combustion. Now if the unit had a secondary heat exchanger it would capture the heat from the firebox. Just something to chew on. If the unit already has firebrick on the walls of the furnace then I wouldn't add more to the sides. Only so much can be done without the addition of heated secondary air.
freeburn said:So the heat isn't going to pass through the firebrick into the metal jacket and keep it hot longer? Firebrick then is more of an insulator for the fire than the metal around it? Am I understanding that correctly? If that is the case, why do the wood stoves have the firebrick all the way up? Is that only to keep the inside temps up for secondary burn to work?
