Hi, you guys here seem to be my go to for everything because I always get good info. Currently, I have a Dutchwest 2461 in my basement. It’s in a portioned room that opens to the staircase. Our house is 950 sq. feet. Our chimney runs along the outside of our house and to add on I have a 45 degree offset on that. Once the chimney is warm (2-3 pieces of paper burned) our draft is fine. My question is the Dutchwest is a little too small for our house. Our house is well insulated but the stove will only keep it around 66-67 with it running hard. Also overnight burns seem to be nonexistent. So I was searching on this forum and Englander's seem to get a pretty good review. I looked at the NC13 and NC 30 and the 13 is about the same size as our current stove but the 30 is about 33% bigger. Also, it has a hook up for an OAK which I think would benefit us being that our house is rather tight. I measured the inside of our firebox and the usable space in the Englander and came up with about 1 cu ft. difference. I keep reading that you can always build a smaller fire in a bigger stove but not the other way around. I am just worried that the 30 might be too big and cook us out of the house. Any inputs?
Thanks.
Thanks.
