Hey guys! First off, thanks for all the help getting me set up! I got it all buttoned up and ran it for the first time yesterday. It being a Englander 25PDVC. So, since this is my first time ever using a pellet stove I was constantly watching it, trying to figure out if ever thing was going well and checking the forums. It seemed to have burnt very well, even with what seems to be a "junk" pellet. But, I ran it on 2 for about 3 hours and then knocked it down to 1 because it got really warm in here (which in no way am I complaining about) but my bag of pellets only lasted about 12 hours. The temp outside was 25-33, and the sun was shining in so I'm sure that helped with the warm up. But is this running too hot and eating too many pellets? I read a lot of posts about a bag lasting a day in the dead of Winter. With being on the lowest setting and it running that hot and using that many pellets, what adjustments should I make? My bottom 3 are set at 6-4-1. I adjusted it to 5-3-1 but the burn got dirty and since it was running clean and seemed to be burning all the pellets I went back to how it was. Thanks for any help in advance!
![[Hearth.com] Englander stove pellet use [Hearth.com] Englander stove pellet use](https://www.hearth.com/talk/data/attachments/143/143400-2419f347294c7e5127ef01043c6ff87e.jpg)
) Do you know what your exit air temp is? I've just started keeping track of different stove settings to see how they effect the exit room air temp. I gotz to git me one of those stove thermometers, so I can add that to the little spreadsheet. The rate of room airflow should effect the exit air and stove temp, given the same burn rate. My first test didn't bear that out though ... the room air exit temp actually went up, when the room air blower was pushed to 9 .. without changing anything else. ???
