Just had an enviro m55 installed was working fine on 3 setting good flame after a few hours flame went down and I put it up to 4 and 5 can’t seem to get flame back I am using green team pellets from Lowe’s
How much ash is there? I would also try a better brand of pellets.Yes they installed a liner through The Chimmeny approximately 12 feet if that. Insert was working fine first 3 hours now loses flame and then shuts it self down very frustrating
Dealer installed even tried high end pellets tonight nothing has changed just seems like pellets are dropping enough just confused because worked for 3 hours perfectlyDid you install the stove or was it the dealer ?
Read the install manual on how to run the stove
and make changes in output , shut down .
If it was dealer installed call him to come
and check it . With out being there I am at a
loss to what to tell you only because
I am not sure witch board is in your stove .
What you have described is a no heat call shut down
Ok seems the problem was the thermostat even though I have it in manual mode I picked up the thermostat I just had it next to my mantle. The stove automatically went on. So I just put the temp way up on the thermostat stove working fine. Just wondering why thermostat is working in manual mode.That stove will burn just about anything nut shells, grain ,corn ,high and low end pellets
even bedding pellets (not recommended ) Brand new stove call your dealer it
could be a control board problem and under warranty
Figured much of the problem out what I am trying to get an answer to is when I am in manual mode does that eliminate my thermostat completely because in my case is does notThe thermostat may not be reading temps accurately - calibration off. I have a cheap mechanical one like that which used to come w/ the M55. When the thermostat is set at 80, the actual temp when it turns off is 74 at the thermostat. Thus check your calibration.
