Hi Folks,
I'm looking into the option of a basement pellet stove and looking into the Enviro Maxx or Maxx-M model. I've been combing through the user manual and noticed the operational modes, manual, hi/low, and auto/off modes. I'm a bit confused on the last two modes especially with the use of a thermostat.
Correct me if I'm wrong but the thermostat in hi/low mode basically sets the blower speed but does it also change the pellet feed rate? So if I have the feed rate at 4 and the blower combustion trim rate at 4 for example, when there is a call for heat does it run at those levels? If there is no call for heat, it lowers the fan speed to minimum but does it adjust the feed rate? I guess I'm trying to understand the purpose of the thermostat and what it automatically adjusts on the stove. Based on what I've read, it simply controls the blower and any temperature adjustments to the heat output are done on the control board?
If I do move forward with this unit, I'll essentially be running non stop (except when it comes to cleaning) so I'm trying to get an idea in my head the optimal settings and positioning of the thermostat etc.
My other question relates to the Maxx and Maxx-M products and the differences. I won't be doing anything other than wood pellets, so the multi fuel is not a requirement - is there any other feature other than the self cleaning burn pot that makes this unit the one to purchase over the regular Maxx model?
Thanks!
Thanks!
