I recently purchased a Enviro Meridian pellet stove. The convection (distribution) blower defaults to the high (5) blower setting when I run the stove on the 3 or 4 heat setting. This normally happens after it has been at that setting for 10 minutes or so. It does not do this on the 1 or 2 setting (I don't think it gets hot enough to trip it). Anyone have any ideas why this would happen?? Rod?? I run the stove on the Hi/Low setting if that matters. I am looking for a nice even heat as was advertised, not something that is cycling up and down all the time. Also, the auger seems a little noisy to me. When the stove starts up I don't here it at all but once it warms up it becomes pronounced and is especilly noticeable on the 1,2,and 3 heat settings (the distribution fan drowns out most of the auger noise on the 4 or 5 setting). I would prefer not to hear it and am wondering if there are any modifications that can be done to eliminate the noise. I must note that the auger is doing its job, I don't believe there is anything wrong with it, just noisy after the stove gets going. The brochure I received boasted about the quietness of the stove and claimed all I should hear is "the pellets gently dropping into the firepot" when it is running. I haven't found my dealer to be real helpful with answers to my questions. Ideas??? Thank you in advance and take care!!
The auger appears to be resting/hitting a rubber stop. I'm guessing that's good?? It is definitely not metal to metal. All screws on and around the auger motor seems tight. Maybe they need a little play???The noise it makes is more of vibration than a grinding. Could I unscrew the auger from the unit (keeping all wires intact) to reduce /eliminate the vibration?? (just thinking out loud). The what would I mount it to???
