Epoxy recommendations for re-hanging maul
Easy Livin’ 3000
3,028
SEPA
After about 30 cords, the epoxy holding the fiberglass core handle to the 8 lb maul is breaking up. I did it in when I pounded on the back of the maul with the sledge over the years.
Looking for recommendations for a tough epoxy to use to stick it back together.
Most hardware stores sell kits for repairing mauls. I've used them without issues...
Reactions: Easy Livin’ 3000
Having played with various epoxies over the years, they all pretty well will do the jobs as long as they are mixed properly. The kits with the dual syringe work pretty well. Just realize that epoxy has low viscosity unless modified, it will leak and seep into any gap so when you install the "dam" at the bottom seam between the handle and the head, it has to be tight or otherwise it will leak out and make a mess. FYI even though it doesnt smell nasty, ti can give folks contact dermatitus, its best to use rubber gloves when handling it as eventually you can become allergic to it.
Definitely clean out the gap well and hit it with degreaser as it doesnt bond well to grease.
slow cure epoxy. Not the 5-30 minute type. Roughen up the inside of the head as well as the shaft. I've
cut horizontal grooves in the head to give the glue some xtra grip.
Peakbagger's right...the stuff flows like water, so make sure u tape up the bottom of the maul/handle so
nothing leaks out.
What brand is your maul? Some have unlimited lifetime warranties.
nothing leaks out.
It's all good these days, even the quick cure. Epoxies have come a very long way in 15 years.
I have found nothing better than Scotch-Weld.
Here is one made to work well with wood. https://www.amazon.com/dp/B000WXFKBY/?tag=hearthamazon-20
Here is the product selection guide to choose your own.
(broken link removed)
It is pricey, but I have always been impressed with it.
I would blast the area out a few days before with brake cleaner to make sure there are no residual oils. It is all about the prep.
I think it's a Bobo. Pretty sure no lifetime warranty.
If it were a Fiskars otoh, I'd have me a new one already. They recently sent me a new lopper blade, no questions asked.
