STIHLY DAN
I couldn't ask for a better functioning controls setup. I really like how it turned out.
Love it when a plan comes together.
try sticking that Tundra in your living room. lol I bet it out heats the insert. I used to have tundra in an non insulated shed 12x20 and it would get the high 80's lol. hot. windows open when its 5 deg outside. But I get it. U mean vs the duct delivery of the heat.Yeah, the fan/limit switch.
Not sure I'm following the plan with the blowers and dampers...
You might be surprised...my lil Drolet 1400i (1.8 CF insert stove) will out heat the Tundra 2:1...but, that it only the main floor, and a load only lasts about half as long as in Tundra
It's not really a safety hazard...the cracks close up when it gets hot...never hav
Thanks - Appreciate it. Anybody else still burning theirs with cracks?It's not really a safety hazard...the cracks close up when it gets hot...never have welded mine yet...it works fine. But with 6 cracks that long, welding might be prudent to keep things from getting completely out of control though...
 Needless to say, you're now aware of some potential mitigations such as firebrick for the front face (available from SBI), over-temp control, etc?  I don't know how much that helps, but some ideas for you...
  Needless to say, you're now aware of some potential mitigations such as firebrick for the front face (available from SBI), over-temp control, etc?  I don't know how much that helps, but some ideas for you...Yessir, I'm still using mine with cracks. I have probably the same number of cracks as you @Woodythewoodhunter , between the 8 corners of the loading door and heat exchanger cleanout door, although all but one of mine are <1" long. I also bet that if you look underneath the HX cleanout door, you'll see a bunch of tack weld that are cracked (right above the loading door).
Although I don't like the cracks and I figure the days (years) with my Tundra are numbered, I also feel safe using mine in its current condition. When the furnace heats up the cracks shrink closed, so I don't think air admittance is affected much. They're far from a through-crack, and they're plainly visible to keep an eye on them so I can tell over time if they're running away.
I'm kind of curious what new furnaces might come out in the next couple years, and for now I'll see if I can make it that long.
Also, I'm super impressed you read all 105 pages. Do you have insomnia?Needless to say, you're now aware of some potential mitigations such as firebrick for the front face (available from SBI), over-temp control, etc? I don't know how much that helps, but some ideas for you...
Actually I did get the warranty, I even confirmed that they were ok if I ran it until I chose a replacement, they said sure.
Gosh sorry about the insomnia joke. I can tell you're not offended, which I'm glad you know that wasn't my intent. I hope you sleep better tonight.
Hi @Case1030 ! Sounds like you have a well thought out plan. The extra foot of firebox that the TII has over your insert stove should provide the firepower you need. Are you running ducts in the attic, or crawlspace?
BTW, dad used to own (still has?) a Case 930...what a chunk of iron!
The emergency heat dump is exactly what I was going to suggest, but you are already on top of it!Id like to duct through the crawlspace if possible and rig a heat dump in case of power outage.
Nice work with the Mypin on your insert too! I think you could lower the operating temps some, gain some efficiency...a fan stripping heat off the outside of the unit affects the temp inside the firebox very little, if at all.
I can get secondary burn going at 350-400*F in my Drolet 1400i stove (with 3 year CSS wood)With lower mc% wood I think you have a good point, logs should light secondarys at 450 stove top.
The temp I ended up settling on for the Mypin temp controller on the Tundra was 350*F to close damper, 300* to open back up (if there was still a call for heat) but that is measured inside the stove pipe a foot or two out of the furnace....not sure how that would translate to STT's.
My thinking too...people tend to squawk about stuff that doesn't work...especially $2000 house heaters!I haven't been able to find to much regarding the tundra 2 though... I guess in a way that's a good thing.
My understanding is that it is the basically same, only with manufacturing changes made in the front to eliminate the cracking issues (the HE cleanout box is allowed to float now instead of welded fast to the front firebox panel, for one) and the blower controls are more sophisticated...variable speed. And then the obvious, the plenum...all steps in the right direction IMO.I was a little curious about how the old tundta compares to the new design with the plenum?
Just curious, how did you attach the thermocouple to the stove?Not exactly related but I do have a stove top tempurature controller on the unit. It kicks the insert fan on high at 600 and a exterior fan blowing in the fireplace opening. At 590 fan goes on low also kicking off the exterior fan as well keeping firebox hot enough for secondary combustion. So I like to believe im getting most of the btu out of this unit possible.
View attachment 232919 View attachment 232918
