Excess pellet usage on EP-25
dubbz
64
Pocono Mts, Pennsylvania
My EP-25 all of a sudden is burning like it's on a feed rate of 4. My bottom 3 buttons are 1-5-1. It was running great all winter. I only adjusted the feed air rate to 5 to get a better burn. Since the feed rate is on 1, i'm scratching my head wondering why it's feeding so many pellets. Any thoughts or help would be appreciated.
Washed-Up
595
Kananaskis,Alberta, Canada
Has it been thoroughly cleaned recently?
SidecarFlip
Does that include the venting and did you do the suck out / leaf blower trick? Sounds to me like it has a blockage somewhere. Always eliminate the easy stuff first.
SidecarFlip
Thanks , I will do a major cleaning again.
I'd be concentrating on the venting. Sounds like a partially blocked vent pipe to me.
SidecarFlip
Cut the feed rate down a bit......
SidecarFlip
I wasn't aware of that. Maybe you could put a resistor in the feed to the auger motor to slow it down some? I don't know, maybe Sysko does. Not electronics savvy.
