Low flame, low volume pellet feed, low heat
kharrisma
42
Bristol, NH
Hi All - - Englander 25 PDVC. Generally runs fine, but at times the pellet feed is really minimal when set at 8 & 8, with a very low flame, and produces little heat. It'll run for a full 24 hours and the room (20 x 30 - ish) goes from 45 to 53. Ordinarily, a 24 hour burn (at 8 & 8) will bring it up to 68 or 70. It's been serviced just before the heating season; evetything either vacuumed out or blown out, burn pot holes drilled out and passages cleared, , burn pot gaskets replaced, combustion fan blower cleaned and gasket replaced, door & hopper gaskets checked, vac switches test good with Fluke meter, slag at end of pellet feed tube chiseled off, air feed channels all clear... really can't imagine what could be causing this fluctuation in the volume of pellet feed, with such widely divergent performance. I'd appreciate any pointers on what might be a good idea to check next. Perhaps one of the motor/auger couplers is slipping or something like that, just don't know where to take this. Thanks!
