Hi All
I am looking at installing a Jotul F100 eco Long Leg and have an issue with the existing masonry chimney.
The internal dimensions of the chimney are 125mm x 245mm and approx 4m high.
The advice I have been given is that I shouldnt use the chimney and just run a 150mm pipe out the top and through the ceiling
I would prefer to use the chimney if possible because the room is quite small. Is it possible to run 2 x120mm diameter flues next to each other up the chimney?
Any other ideas?
I appreciate the advice
Cheers
Matt
Any other ideas?
Cheers
Matt
