In December I installed a Kitchen Queen Grand Comfort cookstove. This is my first wood stove and my first experience at all with an airtight/tube stove. It seems a little sensitive when reloading. I believe I’ve narrowed it down to the bi-metal thermostat. I roll and twist 4 small pieces of news print and lay on the grate. Then cross stack 2 tiers of kindling followed by a mix of small splits and small 1/4 splits. Air inlet wide open, ash door cracked and direct smoke outlet open. Sometimes I’ll take a piece of rolled news print and set it on top at the direct smoke outlet opening to warm the flue. I light that one then the 4 on the bottom, close the firebox door and within 30 seconds to a minute I latch the ash door. No problems. Once the probe in the pipe has reached @900 the thermostat has closed the door down to a small gap. I’ll close it completely at this point and the stove will coast along @600-700 at the probe and then cool down more when until there is a small bed of coals left. At this point the thermostat has the door mostly closed even if I turn it up all the way because there is so much heat in the stove. Now the dance begins. If I put too much wood in it smolders and boom. The salesmen told me to crack the ash door until I have a flame. That’s fine but now I have to get the door latched again without causing to much of a change or “whump”. It’s a good thing it’s a cookstove because the lids allow the pressure of the explosion out.
