File life
Seems the better you get the longer they will last. When I first started filing it seem like I would go through a file on just a few chains. Now it seems they last quite awhile dozen or so.
Reactions: Nixon and Thistle
Longer when you dont hit any rocks,embedded chain link,large spikes or other debris with the saw chain. I hit some hidden fence wire in a walnut stump last Fall,took quite a few sharpenings before all the teeth were back to normal again.I used Oregon files for many years,switched to Woodland Pro (made by Carlton I think) in late 2011,cost was a bit less for even better quality/longer life.Buying them in a box of 12 is much cheaper too.
Reactions: smokinj
Keep them clean, (I spray with starting fluid to clean them, out doors ;) )
Only make chain contact when pushing forward, don't drag it back thru the cutter.
Should out last a few chains.
Good one should last a long time.
New chain: New file.
Reactions: MasterMech
