Finally finished my block off plate and OAK!
tpme06
41
Newmarket, NH
I was able to get an OAK kit for my Harman Accentra insert so I installed it along with a block off plate this past week. Needless to say, my measurements weren't too bad with the exception of the holes for the exhaust and intake flex pipe. I used 4" pipe for the intake. Thank goodness for furnace cement to cover my mistakes :)
  • [Hearth.com] Finally finished my block off plate and OAK!
Looks like it'll work. You may kick yourself for not using the more flexible RTV Silicone,
as the furnace cement will eventually dry out & crack & chip, but that
shouldn't happen for a couple of years down the road...
Good point, something I wouldn't have thought of... I even had it with me when I did this, as that's what I used on the 3" pipe actually on the stove. Oh well.
Roxul fire proof rock wool insulation can be used on top of the blocking plate to keep the room a little warmer too.
You will be happy you did it! I second the roxul! Stuffed mine solid before installing the bock off plate.
