Hello all,
First season burning wood as a heat source for my wife and I. The house we bought has an Englander 28-3500 which seems to be in okay shape. I had the chimney swept and I replaced the firebrick/door gaskets before the start of the burn season.
I understand it's a terrible year for cord wood, which may result in abnormal burns but our stove seems particularly fussy. I've been very cautious with flue temps and bought an Auber Instruments AT210 to monitor them (screwed washer to single wall, 18" above stove).
I've read that ideal 'cruising' flue temps should be in the ~350* range, but ours seems to be much happier in the 400-425* range. Is this an issue or is it okay to keep these temps sustained for ~2 hours at a time? The other issue is that the stove has a sliding air intake adjustment on the front, and despite it having ~6" of adjustment, only about ~1" seems to mean anything. This results in the slightest movement of the slider to cause drastic changes to the burn temps. VERY frustrating at time. One second it's creeping into the mid 400* range and a 1/4" slide of the intake adjustment sends the fire dipping into the low 300* range and about to die out.
Side note: I also bought a moisture content meter and have been careful to not burn anything that is above 20%.
So is it me, or the stove? When I vent at work about this, the guys that also burn wood chuckle at how particular I am with it. Most just throw some wood in it and as long as it looks good leave it alone. I can't help but wonder if I'm over thinking it.
