I have a Fireplace Xtrordinair gas fireplace, (model 36DV) that was installed about 1997 or so. I removed the glass front to clean the inside of it.
The gasket is U shaped, that fits all around the glass, then the glass with gasket on it fits into a slot, and is somewhat clamped with a continuous piece of metal all the way around.
I can't find a U shaped gasket. Was thinking of using something like this.
Also, is there any special gasket cement used for glass??
http://www.mcmaster.com/#fiberglass-seals/=x07w74
Does anyone have any other thoughts on replacing the gasket on a glass front, gas fireplace.
Thanks.
Thanks.
