Ok - I know this is apples to oranges in many ways and everyone will have opinions, but I'm looking to compare a rather specific aspect of these two stoves and want some feedback.
What I'm wanting to understand here is the heat output. I'm looking at the published specs of these stoves and trying to understand if they are comparable in terms of how much heat they pump out if running at full tilt (without pushing overfire condition).
Fireview specs say:
Firebox: 14.5" x 13" x 20" (Which I calculate to be approx 2.1cuFt)
Area Heated: 900-1600 square feet
Max Heat Output: 55,000 BTU's/hr
Heat Output (EPA Test Method): 10,800 - 42,100 BTU's/hr
EPA Efficiency: 72%
Encore NC specs say:
Firebox Volume 2.1 cubic feet
Heating Area (Max) 1900 sq. ft.
BTU/h (Max.) 40,000 BTU
BTU/hr Range EPA Test Method 10,600-24,050 BTU/hr
Efficiency 68 %
What confuses me here is that the Fireview has higher rated heat output (both Max and EPA test method range) yet lower "Area heated" spec) than the Encore.... What gives here? Just a more conservative estimate by the company to avoid disappointment by customers?
I realize I'm comparing a NC versus a Cat stove... such is life
Secondary question/comment - I assume the difference in rated efficiency is likely moot given that operator style will make a larger difference than that 4% rated differential there...
In case you are wondering, yes I am building a fantasy about changing stoves. Not so much a "I don't like my Encore" - I actually like it quite a bit, but more a desire to find a stove that can I can run myself - i.e. I can let run all day on a load and not have to rely on others in household to feed. (And I'd like to really get an overnight burn). I call it a fantasy of course since the loss I would take in changing stoves would be crazy financially - I don't even know how much $ value my Encore lost in one season of burning...
Fireview specs say:
EPA Efficiency: 72%
Efficiency 68 %
