This season I made the switch to a wood stove, a BK King. Last night I did my fist burn to cure the paint and this morning I had another to warm the house. I took some pictures and I also have some questions.
BTW, I'm burning seasoned lodgepole pine.
Here are some pictures of the start of the burn.
(broken image removed)
Now it's roaring.
Fire starting to calm down a little. Didn't take long for the dog to find it.
Now here are my questions.
The entire time I was burning I had the T-Stat set to the max. The highest temp I got was 550. The last picture I showed was still with the T-Stat at max, and some wood still in the firebox. Should I be getting higher temps? Am I doing something wrong?
This morning I started another load with a couple splits and two whole rounds. Since it's warmer outside I turned the T-Stat down to 1.5 (slowly over time like that manual states). I started the burn at around 8:30, and it's 12:20 now, so almost 4 hours. I'm watching the cat probe drop (almost inactive now) and the stove top temp is down to 200. Does this seem like normal behavior? There rounds I threw in are still intact and I'm wondering why the stove is going to go inactive while there is still fuel in the firebox.
Here's a video of the active burn for all you junkies.
Now it's roaring.
sounds about right, but leaving the T-stat maxed out doesn't. You need to install a probe thermometer, you'd be surprised how hot your flue will get before the Cat even gets to the active zone.
