Hi all!
This is my first post after lurking and re-learning for about a year. Thank-you for the information and advice freely given!
Last winter we just started burning wood again after about 25 years without. With a ready supply of wood very handy as well as the necessary tools always at hand what the heck were we thinking? The wood heat is wonderful, warm, and comforting.
Anyway, I was wondering if it is ok to lay a plate of steel on top of a plate-steel stove to use for a cooking surface. Not a surface to put food on, but a surface to put pots on. I just happen to have a piece of 3/8" plate laying around that would work nicely if I cleaned it up and painted it. I just want to try to keep cooking splatters off of the stove as much as possible and since the steel sheet is a bit oversized I'm thinking it would give a larger temperature range with which to work. Also, it would be easier to clean and re-paint a sheet of steel from time-to-time rather than the stove. This would be on a Drolet Legend III. Would this compromise the stove-top in any way?
regards and thank-you very much!
