Hey Guys...I did my first real fire after breaking in my recently installed Hampton HI300 with 3 small fires to cure the cast iron/paint, etc. I burned from late afternoon yesterday/overnight and was able to keep my entire 2 story Center Hall Colonial (2000sq.ft) nice and toasty (about 74 degrees) without using the electric heat pump. It was not really cold out last night (about 37 degrees), but I was impressed that it heated the house so well. I have an open floor plan and a fairly open staircase and used the living room ceiling fan to help move the heat around.
So here's my question...I have a condor stove top thermostat right at the top of the door in the middle (where dealer said it should go for accurate temperature)...but the stove reading never went above the low 400s which I believe is the low side of cruising temp? I'm a newbie to all of this and will admit that I am that I just build a tepee kindling fire with newspaper, let it get going and then start to throw some splits on top. I then knock down the air intake a bit when it's established. However, I was really afraid of over firing the insert with my first real burn, but was surprised that the thermostat took quite a while to get to 400 degrees and never went much above that? I know I probably could have fit more splits in, but again am a little anxious about over firing. Is the way to really run this stove efficiently to pack it full of large splits get it the heat really cranked up...then start knocking the air down?? Thanks for any feedback you can provide...I really thought the thermostat would be jumping to 500 or 600 pretty quickly and this was not the case??
