First time stove owner and burner here. Have a 52i insert and have been enjoying it this last week, burning in the mornings.
What settings are you all using? Right now I've Been burning for maybe 5hours each day. I've been mixing it up between using room temp and constant on. Feed rate at 3.
What setting will use the pellets most conservatively ? Should I set the feed rate lower?
Should I use the constant on feature and set to low as a way of maintaining the room temp and avoiding overuse of the igniter? Is it bad to throttle down?
And when full winter comes how day you set your stoves to run? I'm assuming you run the stoves 24\7
Let me hear from you gurus. Thanks
correct me if i'm wrong)
