We have a 1550 square foot American Foursquare in Massachusetts with about 700 sq ft on the first floor in a fairly open layout (cased openings between front hall/staircase, living room, dining room, and kitchen in a circle). The second story is much more closed off and we don't get much airflow between stories. There is a disused single flue masonry chimney (16" x 20" exterior dimensions) that runs through the center of the house and exits above the peak of the hipped (pyramidal) roof, so we should get good draft; we would certainly run a metal chimney inside it because we know the masonry chimney can't handle flue gases.
We are planning a corner installation in the living room and intend to use the stove for coziness and as a backup in case our electricity-dependent gas hot water system (with cast iron baseboard radiators) fails. We don't expect to be able to heat the upstairs well with the stove and don't want to get overheated downstairs, and don't expect to be doing overnight burns. Power rarely goes out here and we are usually the first ones to get it back, but a few years ago (before we lived here) everyone here lost power for 4-10 days. Last winter we had -20 temps (-40 with wind chill) and a 10-day period where it never got above 20F, so a backup heat system would be welcome. If we are out of power for long I figure we will all just sleep in the living room for a couple of nights.
A local store steered us to the Hearthstone Craftsbury and Tribute, the Jotul F3CB, and the Lopi 1250. We don't like the Jotul styling, the Tribute seems difficult to get 16" wood in, and the Craftsbury is beautiful but reviews here make it sound unreliable and finicky. The Lopi is much cheaper than any other option. We don't love it but would be fine with it, and it seems to have a reputation for simple reliability. So - should we go with the Lopi, or reconsider? Will the Lopi fit on a 48" square corner pad? Am I missing anything?
Thanks!
Thanks!
