i have a 1980 Fisher insert, model G635449. My fireplace chimney opening seems to be set deeper than where it lines up perfectly to the insert's damper/chimney. If i completely shove my Fisher in as far back as it will go, it is set 3.5" too deep for me to attach the top and side metal pieces. If i slide it forward so the metal pieces attach, it seems to be a little too far forward for the smoke to vent properly up the chimney.
So what is the correct depth for me to set this insert at? If i push all the way back, will it heat up the brick chimney too much?
Thanks
Thanks
