I noticed my damper was sticking and found the dreaded baffle crack. The baffle is welded in and bowes up and splits with time. The metal is still very thick. I was unable to pound it down with a sledgehammer and chisel cold. I fired the stove outside and then was able to pound it down. My question is should I leave it split so that it has room to contract and expand? Should I put a weld bead in it? Should I weld a plate over it from the underside?
The stove has been run throughout its life with no fire brick and his hands-down the best woodstove I have ever run. We have several wood stoves at all of our properties and I would give anything to have all of them be these. Needless to say, I would like to repair it and get as much life out of it as possible. This one has been burning for 40 years at our farm.
![[Hearth.com] Fix dreaded baffle crack on awesome Kent stove? [Hearth.com] Fix dreaded baffle crack on awesome Kent stove?](https://www.hearth.com/talk/data/attachments/342/342573-814766d48e4db16e5445bbf7fca8f552.jpg?hash=NcxBXPE8hN)
![[Hearth.com] Fix dreaded baffle crack on awesome Kent stove? [Hearth.com] Fix dreaded baffle crack on awesome Kent stove?](https://www.hearth.com/talk/data/attachments/342/342574-e23c20e0a6e099ef47e35dba82a374f3.jpg?hash=FKsURw7H3F)
![[Hearth.com] Fix dreaded baffle crack on awesome Kent stove? [Hearth.com] Fix dreaded baffle crack on awesome Kent stove?](https://www.hearth.com/talk/data/attachments/342/342575-5e22716da5804fa7d0f92f8efc2a84ed.jpg?hash=ZFShVYjWmX)
