Good Monday evening!
(even thou it's MY Friday ;-) )
I'm kicking around the idea of installing another stove in our den/living room/game room.
The Overview -
The house is a 1918 ranch. The attached garage was remolded into an apartment for the former
owners' father in the late '70's/early '80's. 2 x 6 walls; 2 x 10 (12 maybe - long span) ceiling.
This past summer we replaced the roofs, both on the main house and the apartment. The old
hot tar was replaced with 1-4" of tapered ridged Styrofoam insulation, due to poor drainage. It
now has an EPDM rubber roof. It's about 28' wide and about 16' deep - a single piece of rubber.
There is NO attic above or crawl space below.
The wood floor will need a hearth built; it's over 3/4" ply over 2x4, on their side (sleepers)with
homasoap (sp?) between the sleepers, over 1/2" foil cover ridged Styrofoam insulation, all over at
least 4" of poured concrete over soil.
The Question -
What kind of chimney support box should I use - A pitched roof (1in 12 to 7 in 12) or a cathedral
support? Since there is no attic, I would ASSume that all the support will have to be installed
inside, under/around the sheet rock. I know that there is at least 6" of fiberglass insulation up there,
so I guess that I'll need an insulation shield also, correct?
Also, would it be necessary to have the roofers come back and flash around the flashing,
due to the EPDM roof?
Thank you for all your help. Hearth.com is an insurmountably source of information with all your inputs
and ideas!
The Overview -
The Question -
and ideas!
