I installed a 5.5 flex liner in a masonry chimney that terminates through the wall with a tee snout. Last night I poured the insulation down the 27' chimney, when I was done I came back in the house to get cleaned up and noticed some of the insulation in the snout. After looking at it closer I have a gap between the tee snout and the main body on the sides with the clamp. I don't know if this is a case of just poor fit and finish or if I have something wrong. I'm not sure if I can tighten the clamp more and pull the ends of the snout toward the body more or not. I didn't notice the gap until the insulation was poured down so I'm pretty limited and ways I can fix this issue since the chimney is full of insulation and the snout in mortared in the wall.
I'm going to try to tighten the clamp more tonight if that doesn't work I'll try to bend the body opening into the snout to help close the gap.
Can I use furnace cement inside the liner snout/main body to fill the remaining gap?
Any other suggestions?
