Hey all,
In the final stages of planning before installing my PE Super 27 this fall. Got the stove placement all figured out. Now I am working on finalizing up the hearth plans. Ideally it would be a self made floating hearth. Super 27 only requires ember protection. And the location where it is going is on top of our year old hard wood floor living room. So the thought is with a floating hearth we can do no damage to the floors and have flexibility in the future if we move. Central IL is not exactly a hot spot for wood stoves. Also trying to make the hearth as thin as possible while safely supporting the stove. We originally wanted to do flush hearth but damaging the wood floors has lead us to the floating hearth idea. The hearth size will be 54in wide and 48in deep. So I was thinking using a single sheet of plywood with cement board on top and slate tile on top of that. It will all be secured in place by the outside trim.
So I guess the main questions here are what thickness of plywood and cement board? And for those who have constructed a floating hearth before, how did you do it and did you like the results? Thanks for any comments.
