I recently installed a new chimney. It's 14' double insulated stainless out the roof and 6' single wall to the stove with 2 45 angles.
I am looking for a probe thermometer to get the flue temperature. My plan is to put it right below where the single wall meets the double. I will place this in the location in lieu of a screw holding the pipe.
What temperatures should I be looking for? I have one of these ir thingies but when the stove gets hot it always reads OH which is no good to me. I think it's over 700 you see that if I remember correctly. Why I bought one with that feature I have no idea so you can suggest one of those too.
I am trying to get my head around why I want so much heat going out the flue. When I put the stove in I was green while I am still a newbie I'm learning. I have a damper installed but have never used it until now...I did just go damp it down because I was writing this post
Your suggestions are appreciated. What kind of results should I expect? The wood is ash a year old 15-18% moisture.
. Your suggestions are appreciated. What kind of results should I expect? The wood is ash a year old 15-18% moisture.
