Cheaper flue thermometer alternatives?
kevk
51
Georgia
I have a wood stove with double-wall pipe, and I’ve been reading that I need to monitor the internal flue temperature. Apparently you’re supposed to use a special thermometer with a small probe that installs through a drilled 1/4" hole in the outer wall.
I checked Amazon and they’re like $40, which seems ridiculous for what it is. Is there a cheaper alternative or DIY option that works just as well?
Yeah they are all pretty close to $40 and they aren’t always very accurate. A lot of people here have gone to the digital Auber thermocouple probes that are much more accurate and quicker to react. But they do cost more.
^^*^^ If not going digital, get the Condar.
BTW, I once bought (cat probe) Condar thermometers on Amazon. From what was labeled as "the Condar store".
They kept shipping the wrong (length) ones. I returned 3 times.
Then I called Condar. Turns out the "Condar store" on Amazon is not Condar. They're upset about that but can't change it.
If you buy one, I suggest to directly buy from Condar (website above).
Small company, I believe in SC. Nice folks. You can even call in an order, reading your credit card number to them on the phone (at least that is what I was offered) .
ScAmazon......I pretty much do 0 business with them.
I do my best to support businesses here.
Reactions: Pinesmoke
You have a several thousand dollar system for heating your home. Now its time to make sure that system is being operated safely. Everyone with a wood stove in their home should also have a fire extinguisher handy. But more importantly, a probe is a device to help ensure you will never have to use your fire extinguisher.
Buy once, cry once.
What about this brand?
IMPERIAL Flue-Gas Stove Pipe Probe Thermometer KAL KEM
Doe it have a guarantee or warranty? If it's not relatively accurate then it's a waste of money. I haven't tried it but had a couple like that, they were worthless.
The design looks similar to the Condar, and is also supposedly made in the US. Or are you staying stay away from the analog type and go digital?
Reactions: Burnin Since 1991
I have had both styles. The Condar was in place for years. It's good, but when I added a digital probe, primarily for the alarm system, I was surprised at how slow the analog thermometer was next to the digital. With the old analog probe I was often having to turn down the air earlier due to it being a lagging indicator as the fire strength grew on a fresh loading. In contrast, the digital is real-time, allowing for much better control on startups. This thread shows the difference.
I upgraded my digital to include a wireless remote repeater so that I can view the stove flue temp from my office. That's been a real help.
