Hi All,
I'm curious what I should be expecting for a flue pipe temp (external reading) vs a stove top. I feel like my draft is too strong and is sucking the heat out of the insert a bit too quickly.
The secondaries seem a bit more strong/fast than I'd like, although I am burning almost exclusively pine, so that may have an impact. Typically I have temps like below.
450 STT liner 275-300
550 STT liner 350-375
650 STT liner 400-450
Those liner readings are on flex liner about 6 inches above the insert.
I know it is typically recommended that the reading be taken about 18" above stove top but I can't do that with my insert...I can only see about 6 inches worth, the rest is above the blockoff plate.
So are those temps ok?
How much difference is a reading at 6" like I am vs the recommended 18".?
What do those liner temps suggest for an internal exhaust temp?
