I have an older Mendota wood burning fireplace. Which after a lot of experimenting, I think I have finally figured out how to use it for best effective heat generation.
One thing I would like to do is to able to get an accurate read on the flue temps. Since it is a built in install, and the flue goes up the outside of the house, in a fully enclosed wood framed chase, one of those magnetic units wont work. My only access to the flue is the space just above the firebox, in the plenum area. The built in portion of the flue, about 10 inches, before it exits the top of the unit is available, but it is recessed about 15/20 inches from the front stone facing, and hidden from immediate view by a removable grate that the heated plenum vents into the room from. I am thinking that if I could find a temperature gauge that uses a wired remote sensor that could be attached directly to the outside of the enclosed flue inside the upper plenum, with the temperature read out mounted on the vent grate that might work.
Anybody have any ideas or thoughts on a temperature gauge that would work in this situation?
Thanks.
Thanks.
