Hey all!
First off I want to say that this forum has helped me not only with my decisions on purchasing a stove but also my burning practices. There truly is a wealth of knowledge here.
I've been lurking on this site for a few years and haven't quite found the answer to my question, so I have decided to post to receive personalized wisdom from the folks here.
Although I live in a warm state, my house sits in the mountains and often times we see very low temps during the winter. It's suppose to be close to single digits the next few nights.
After building our house, I had installed a "homemade" stove that was built with plans like that of the old Papa Bear stove. It heated the house great, but I had a chimney fire the second year it was in use. I now know it was because of poor wood and even worse burning practices.
The current set up that I have now is an Englander NC30, in the basement. From the stove, single wall runs about 3 feet up, then makes a ninety degree turn through the concrete basement wall. From there it is exterior Class A chimney that runs, give or take, 30 feet up.
So my question, I believe I am running the flue temps a little hot. In order for the stove to be at cruising temps (550-600), my flue temps, on a magnetic thermometer, jump up to around 500 degrees before I have the stove shut down. Once the stove starts cruising, the temp falls down to around 400-450. Everything that I have read on here says to multiply the surface temp on the flue by 2x or 1.5x. Is this too hot? I have tried shutting the stove down earlier to get the flue cooler, but the stove top temp just doesn't get to where it needs to be. I also have a key damper in the single wall, with having such a tall chimney, but it is more for emergency situations than anything.
