Foil tape
Use it where? And which foil tape are you refering to?
Use it on the pipes that connect inside to my pellet stove. One pipe is a straight pipe and one is a 95' pipe. I wondered if I can put the reflectiixinc aluminum tape on the pieces that connect? There's a error code that keeps coming up "E1" which indicates a vacuum lose. I've done everything else so I'm wondering if the lose is coming from the two.pieces that connect. I was able to tighten the pipes and link them tighter so I hope that did the trick otherwise I was going to put that tape on it but it said it works on temps up to 180' and I think the pipes get hotter than that when the pellet stove is running
Better to use silicone tape. Expensive but I buy it by the mile from this seller on eBay, cheap. In a variety of colors. It is not the heavy weight variety but in places where I need thicker I just do two wraps.
(broken link removed to http://www.ebay.com/itm/Black-Silicone-self-Fusing-Tape-8-rolls-2-free-rolls-/131691170954?hash=item1ea967cc8a:m:mpeoRuO9Nj2HwxJYUqucqUQ)
Well you answered youre own question.. no that tape will not work.
A leaky exhaust should not cause vaccum loss anyways. You say you have done everything.. what exactly have you done?
