I have a 525ft rec room that is above a garage that is absolutely frigid. The rest of upstairs is 64 degrees and the rec room is 57. The rec room got all the way down to 49 degrees the other day. The rec room is an in between level that is above the garage. The house is about 3900sqft. I am using a FPX large hybrid insert downstairs to heat and some oil that is used by a hydro air heating system. I don't use the oil often. The problem is that the rec room is not a separate zone. I have gotten different ideas how to fix the problem. I have looked into radiant, adding a modine heater in the garage, adding a damper in the upstairs air handler to make a separate zone for the rec room, baseboard heat (which I'm not nuts about) or adding a zero clearance fireplace.
Any thoughts on my situation? Any thoughts on the FPX elite 44?
