The latch on my ash door didn't want to turn when I went to empty the pan tonight.
I ended up opening it with a pair of vise grips, but I really don't want to have to do this on a regular basis. I had some creosote on it, and on the back of the door that I burnt off with a propane torch. It still turns a little tough.
What's the best way to loosen this screw?
Matt
Matt
though it is a good lube and I'd consider it suitable for this application. My preferred bike cable lube is a green aeresol can called "Cable Life - 70" or some something like that. It's been around for years and is the best stuff I've ever found for cables, INCLUDING graphite and teflon. I found that graphite doesn't last well, and the teflons that I tried picked up crud and turned into "chewing gum". The trick is to get a lube injector which is a little aluminum clamp dealy with a split rubber insert. The process is to free up one end of the cable, and stick it into the rubber insert so that the cable sheath is clamped on one side and the cable end sticks out the other. This makes a (hopefully) air and liquid tight seal. There is a little hole in the insert for an aeresol "snorkel tube" - stick the tube in and spray till it drips out the other end. It doesn't gum up the cables and lasts well enough that I only need to do it about once a year.
